Fax Speed Dials
A speed dial is a collection of fax numbers. When you use a speed dial, you automatically send the fax to each fax number that is included in the speed dial. Set up a speed dial for a group of fax numbers that you commonly use together, such as a distribution list. Assign a name to the speed dial so you can easily identify the group of fax numbers.
Use this page to add, edit, or delete fax speed dial entries to and from the device. You can configure up to 100 speed dials. Each speed dial you create can contain up too 100 separate fax numbers.
Adding or editing a fax speed dial entry
All 100 of the fax speed dials are listed in the fax speed dial list. The word "available" appears next to the speed dials that have not yet been configured.
Note: Entries added to a fax speed dial only contain a fax number. The name associated with the fax number in the address book list is not added to the speed dial. This is different from entries in an email distribution list, which consist of e-mail addresses and their corresponding names.
To configure a new speed dial entry, or edit an existing entry, do the following:
  1. Select the entry in the speed dial list and click Edit Speed Dial.... If you are creating a new speed dial entry, be sure to select a speed dial that is marked "available". The Edit Fax Speed Dials Page appears.
  2. Type the speed dial name into the Speed Dial Name field. For example, "Sales Team" or "Joe Smith." The maximum length is 31 characters, or less depending on the language being used.
  3. Add fax numbers to the speed dial list in one of the following ways:
  4. When you have finished adding entries to the speed dial list, click Apply to save the new speed dial list to the device.
    Note: To cancel your added entries, click Cancel . The Confirm Cancel page appears. Click OK to cancel the operation and lose the entries you have added or click Cancel to return to the previous page without losing your changes.
Deleting a fax speed dial list
To delete an existing speed dial entry, do the following:
  1. Select the speed dial entry that you want to delete.
  2. Click Clear Speed Dial.... The Clear Speed Dial page appears.
    Note: If you want to clear all all of the speed dial entries from the device, click Clear All.... If you want to make a backup copy of the entries first, you can do this by using the device Import/Export feature.
  3. In the page that appears, you are prompted to confirm the deletion of the selected speed dial entry. Click OK to confirm your selection. The Fax Speed Dials page appears with the speed dial entry marked as "available".
Error messages
You might encounter the following errors when adding, editing, or deleting fax speed dial entries. The Cause column in this table indicates the possible cause of the error.
Error
Cause
The name field is blank. Please enter a name.
Type in a name for the speed dial entry.
The name you entered already exists in the address book. Please change the name to be unique in the address book.
Each speed dial entry must have a unique name associated with it.
The device is being serviced by the Digital Sending Software at [ip address]. Please use Windows Configuration Utility to configure the device.
The device can be managed either by the Digital Send Service Windows Configuration Utility or by the embedded Web server (EWS), but not both. Go to the Digital Send Service software to make configuration changes.
The address book is being accessed by another user. Please try again later.
Someone else is accessing this address book, either at the device or from their Web browser. Once they have completed their task, you can access this address book.
Functionality on this page has been disabled because of your current browser settings. To enable this functionality, change your browser settings to allow JavaScript.
If the browser settings are adjusted for high security, scripting languages, including JavaScript, are disabled. To use the address book feature, JavaScript must be enabled. This setting can typically be found in your Web browser under Security Settings (set Active Scripting to Enabled) or Content Settings (select Enable JavaScript).
The entry you are editing has been removed or changed by another user. The new information has not been saved.
Someone else is editing this entry, either at the device or from their Web browser. Wait a few minutes and then try again to access the record.
The entry you are deleting has been changed by another user. The entry has not been deleted.
Someone else is editing this entry, either at the device or from their Web browser. Wait a few minutes and then try again to delete the record.
Allowable fax numbers consist of the digits 0,1,2,3,4,5,6,7,8,9 and the symbols [ ] ( ) + * # and the comma. Please correct the fax number.
Correct the fax number to use the allowable characters.
The maximum number of fax numbers allowed in a speed dial list is 100. Please remove some fax numbers from the [list name] speed dial list.
Correct the speed dial list so that it contains 100 fax numbers or less.
