Use the LDAP Authentication page to configure a Lightweight Directory Access Protocol (LDAP) server to authenticate device (multifunction peripheral, digital copier, or digital sender) users. When LDAP authentication is selected as the Log In Method for one or more Device Functions on the Authentication Manager page, the user at the device must enter valid credentials (username and password) to gain access to those functions.
Authentication consists of two interdependent parts. First, the device verifies the user's credentials with the LDAP server. After the device user has supplied valid credentials and has been authenticated, the device searches for the user's e-mail address and name. If either step fails, the user is denied access to the functions that have been configured to require LDAP authentication.
Use the LDAP Authentication page to set up the parameters that are used to access the LDAP server and searches for the user's information. Note that this page only applies when LDAP is selected as a Log In Method on the Authentication Manager page.
The LDAP Server Bind Method setting determines how the device will access the LDAP server. Contact your LDAP server administrator to determine which method will work best for you.
The LDAP Server setting is the host name or IP address of the LDAP server to be used to authenticate device users. When using SSL, the name or address typed here must match the name in the certificate that the server sends.
Multiple servers can be included in this field by separating their addresses with a vertical bar ('|', ASCII 0x7c) character. This feature can be used, for example, to specify primary and backup servers. The network interface only supports a single Certificate Authority (CA) certificate, so all the LDAP servers in the list must use the same CA.
The Port setting refers to the TCP/IP port number on which the server is processing LDAP requests. Typically, this is port 389 for Simple binds or 636 for Simple over SSL binds.
The Bind Prefix setting is the LDAP attribute used to construct the user's Distinguished Name (DN) for authentication. This prefix is combined with the username typed at the control panel to form the Relative Distinguished Name (RDN). Commonly used prefixes are "CN" (for common name) or "UID" (for user identity).
Administrator
DN
This is the DN (Distinguished Name) of a user who has read access to the LDAP directory. The account entered here does not have to have administrative access to the directory. Read access is sufficient.
Administrator
Password
The password of the user who’s user DN was entered in the Administrator DN field.
When the Use Device User’s Credentials method is selected, the Bind and Search Root value is used during both phases of authentication. During the credential verification phase, this value is combined with the RDN to construct the full Distinguished Name (DN) of the user. During the user information searching phase, this value is the DN of the LDAP entry where the search begins.
When the Use Administrator Credentials method is selected, the Bind and Search Root is only used as a search root. The Search Root of the base of the LDAP directory can be specified, and the device will search the entire LDAP tree for the user object corresponding to the username entered at the device.
The string consists of "attribute=value" pairs, separated by commas. For example:
ou=engineering,o=Hewlett Packard,c=US
ou=marketing,o=Hewlett Packard,c=US
o=hp.com
ou=engineering,cn=users,dc=hp,dc=com
When the Use Device User’s Credentials method is selected, multiple bind roots can be typed in this field by separating them with a vertical bar ('|', ASCII 0x7c) character. This can be used, for example, to specify alternate LDAP domains. The device will attempt to bind to the LDAP server using each root in the order listed. After successfully performing the binding, the same root is used to search for the device user's information.
When searching for the device user's information in the LDAP database, the contents of the attribute specified in this field are compared to the username that was typed during authentication. This attribute is usually the same as the Bind Prefix.
After the device user has been located in the LDAP database, the user's e-mail address is retrieved from the database by using the LDAP attribute specified in the e-mail address using attribute of field.
and
name using the attribute of
The user's display name is obtained from the LDAP attribute that is specified in the name using attribute of field.
Use the Test feature to test the validity of your settings before applying them. When you click this button, you are asked to provide user credentials as if you were logging in at the device control panel. If the credentials that you provide are authenticated and the user information is found in the LDAP database, a success message appears. Otherwise, an error message appears indicating why authentication failed.
